Problem with my Zotac 3060 Ti
8 Dec 2020
Hello, I managed to snag one of the Zotac cards, 3 months prior from here. But I have the following problem that go me worried. I have a loud fan rattling sound (I guess the ball bearings are defective), which wasn't there in the begging.Should I wing it because I guess there aren't any cards available due to the situation, or contact support for a change/fix and possibly wait months ?
There was a video on youtube with someone showing the same problem. The solution was to apply some pressure to the shroud on one of the corners. Have a look on youtube.
rattling to me would suggest fan blade catching something rather than the bearings. Bearing noises tend to be scratchy or squeeky
Yep, found the posts on Reddit. It is the shroud when I push on it, as advised, by the posts the annoying rattling sound stops but when I let it go it comes back, I will shove a piece of paper for now. Thanks again !
