Problem with Netgear Security + Nintendo DS :(
19 Dec 2003
UK
Hi folks,
I have a Netgear DG834N , when I enable security
WPA-PSK [TKIP] + WPA2-PSK [AES]
I can get it all working, but my Nintendo DS does not allow that security :( So it wont connect.
The only option I have is to turn off security, and it works.
On my old Belkin Router, I had 4 different security options, and the one I used worked fine with the DS :(
Is there any workaround? Or do I just leave it off :(
I had the same problem, the only way to get it working was to use just mac address filtering, pretty rubbiish if you ask me.
Its upto you, your other option would be a second wireless accesspoint for the DS, turning off security on your primary access point or one of them nintendo USB dongles.
I've just discovered,
by turning the setting to g&b instead of 270MBPS I can get WEP option, which will work with the DS.
Defeats the object of a Next router, but there you go!
