Hello, got a very wierd problem that I dont understand nor experienced, quick spec of rig as is:
Msi Neo Platinum board (skt754)
Ati X1950 pro 512mb (1gp)
Thermaltake butterfly 500w PSU
Kingston Hyper X 3400 (DDR400) memory (2x1GB)
2x HDD SATA
2X DVDRW Roms (IDE seperate channel)
Ninja Scythe Cooler
Recently Added AMD64 754 3700+ Mobile (2.4ghz)
(previously AMD64 754 3000+ 2ghz)
Now the only thing I have changed is CPOU everything is the same and everything workind fine until CPU Change.
The PC will only boot if memory is in DDR Slot 1 it will not boot from any other slot (i.e.2/3) nor if it is slot 1 and another slot. I swapped memory sticks to rule this out, Bios is latest version, I have reset bios to default, I tried changing timings/settings, CPU temps are 10 deg lower than before and nada.
Any ideas??
I know you are going to suggest swap cpu back but would rather not if avoidable.
Is there a known issue or anything or have I borked the memory slot removing memory?
ta
Mike
2x HDD SATA
Ninja Scythe Cooler
Any ideas??
ta
Mike
Could be a dud memory controller on the newer cpu or the fact its a Mobile cpu causing some conflicts with the board.
