Problem with new Cyborg-X joystick
3 Dec 2004
Hi all,
New to flight games so decided to buy an cyborg-x joystick.
It looks and feels great but i'm having problems setting it up.
I downloaded driver + software from online but the shown version is lower then the one I downloaded (on both software + driver).
The main problem is that the FOV 'hatswitch', only works sometimes. Up and down always register but the other directions do not.
Any help guys?
Thanks
Does it show as working consistently in control panel?
Cheers for reply Dano,
No its temperamental. I've seen it work on very few occasions (all other buttons always work fine it's just button 4 + FOV left & right (fov up & down works) . The odd thing is when button 4 works so does the FOV (i.e everything works as normal) but then it goes back to not reading them. I'm guessing it's a lose connector so i've contacted the people i bought it from.
If you can offer any suggestions to try though please do,
Kind regards,
I think you're pretty much on the ball with it being a dodgy connection and contacting the supplier, hopefully a replacement will be all good :)
