Problem with new EVGA 560 Ti 'Classified'
18 Oct 2002
Edinburgh, Scotland
Received my new card yesterday, but hadn't had a chance to fit it into my system until today.
Everything seemed to be going well (no problems fitting the card inside despite some HDD cables coming awfully close), however when I power on the machine, there is no video output. Reading the POST code off the little 7-seg display on the motherboard (Gigabyte EX58-UD5) it's showing FF which means it appears to be booting alright. Made sure that both the additional power connectors were securely attached, as well as double checking the fit in the PCI-E slot, but still nothing.
Swapped the old card (Geforce GTX 285) back in, and everything is running perfectly.
It's an Antec 900 case with what I can only assume is the original power supply, and this is about the only thing I'm not 100% sure would be okay to run a 560 Ti. Would lack of power simply cause the graphics card to not display anything, but still allow the rest of the system to boot?
Mine did this yesterday gtx 480, installed 2 new ram, removed the 2 new ram modules put them back in and it was fine. Computers are so random.
