Hi
I posted this in the customer service section and was told to post here too in order to get help find a solution.
I upgraded my system late last year and have run into some problems with it (spec in sig) The problem usually happens when the system is idle or on one occasion during a gaming session. The windows 7 suddenly slows down and then i cannot seem to click the start button anymore. The mouse however keeps working during this time.
After a short while i get a bsod and the system restarts but does not go past the gigabyte bios logo screen. Pressing f8 or f12 for options does not work either. After a few minutes system will restart and does the same thing again. The only way i can get into bios is to shutdown and power off completely then start again, windows only then allows me to repair start up. I can get into windows but then the slow down happens all over again.
Last time this happened i gave up and did a fresh install and it all seemed to be working fine again. I played games for days (Fc4, ACU) with no problem with an overclock but today whilst playing cod advanced warfare, the pc hung up and i had to soft reset it and the whole windows hanging up started again. My money is on the ssd being faulty but not sure. The problem persists on stock clock speeds.
Even safe mode gives me a bsod.
windows checkdisk returns "File record segment xxx is unreadable" on the ssd.
Hard drive problem?
Thanks
Hard drive problem?
Thanks
