Problem with new rig
5 Sep 2003
I have just build my new rig with an Abit IN932X MAX motherboard. When I first switched it on everything seemed ok but when I went into the BIOS and saved (without changing any settings) an alarm started to sound.
If I clear the CMOS it works ok again but as soon as I go in the BOIS and save, again without chaning anything, the alarm starts to go off.
When I look in the temperature settings the PWM Phase 5 temperature is 130 - 140 where the beep temp is 135.
Any ideas what could be causing it or the temp to be so high?
hasnt anything melted? smell of burning?
you should invest in
The CPU temp seems ok, it sits around 30. The phase 1,2,3, and 4 temp are ok too.
Just phase 5 is high.
i'm guessing that sensor is off big time or somthing on your board is actually broken. Give abit tech support a line and see what they have to say. Prepare to RMA it if I'm being honest.
Hi I have an abit MB see sig do not have PWM5 but pwm4 on my board seems to do nothing and never changes, go into the bios and untick the beep option and that should stop it, I dont know but would guess the sensor is not implemented on that mb model ? I had a similar thing but my beep was fans not spinning but set to be monitored in the bios.
Hope this may help a little.
00NukE
Thanks, I was thinking of turning the beep off but the temp was going up and down so im not sure what its monitoring...
Hey always worth an email to abit but do not think it is anything major or that needs rma but thats my thoughts only. :)
00NukE
