Problem with Nikon D3300
17 Feb 2011
Morning all.
My daughter has just started A Level photography for which we bought her a D3300 (recommended for the course). This has developed a slight problem as shown below. It seems this may have been caused by her dropping it or something to do with her spending endless days at the beach.
Basically there is a dark zone at the top which also appears in images.
I know absolutely nothing about cameras so are there any thoughts about whether this an easy fix or back to the shop?
Thanks in advance.
I'm no expert but it looks like the mirror is stuck.
Can you use live view?
If it is the mirror its not something you can easily fix yourself.
May be expensive to repair :(
Looks like either the mirror is stuck or the shutter is stuck over a 1/3 of the sensor. Either way it will probably need repair.
