problem with ocz reaper
the SPD table often isn't extended above 6400 speeds for compatibility reasons - however the RAM should be good for 8500 speeds if set to that manually - this is normal.
it's normal, my pc-8000 shown as 6400 in cpu-z as well. Ocz did this so the rams boot up no probs with the mobo setting the volt @1.8 as default
ok thanks
is it the frequency im changing in the bois ?
as this is set to manual atm
ive changed it in the bois, but nothings changed on cpu z
frequancy changed to 1066 and voltage to 2.06 ( everytime i done 2.05 it reverted to 06 )
Are you looking at the Memory tab or SPD tab of CPU-Z?
You need to be looking at the Memory tab (will say 533mhz for PC2-8500).
i see
534.3 mhz
the voltages and other info wont show no ?
is the voltage 2.06 ok as everytime i put 2.05 it set to 06 when i hit enter ( can only go up in 2's )
many thanks cob and all others
