*********************** Log Started 2013-07-18T15:53:28Z ***********************
15:53:28:************************* Folding@home Client *************************
15:53:28: Website:
http://folding.stanford.edu/
15:53:28: Copyright: (c) 2009-2013 Stanford University
15:53:28: Author: Joseph Coffland <
[email protected]>
15:53:28: Args:
15:53:28: Config: C:/Users/AppData/Roaming/FAHClient/config.xml
15:53:28:******************************** Build ********************************
15:53:28: Version: 7.3.6
15:53:28: Date: Feb 18 2013
15:53:28: Time: 15:25:17
15:53:28: SVN Rev: 3923
15:53:28: Branch: fah/trunk/client
15:53:28: Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:53:28: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:53:28: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
15:53:28: Platform: win32 XP
15:53:28: Bits: 32
15:53:28: Mode: Release
15:53:28:******************************* System ********************************
15:53:28: CPU: Intel(R) Xeon(R) CPU E5645 @ 2.40GHz
15:53:28: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
15:53:28: CPUs: 12
15:53:28: Memory: 5.98GiB
15:53:28: Free Memory: 4.74GiB
15:53:28: Threads: WINDOWS_THREADS
15:53:28: Has Battery: false
15:53:28: On Battery: false
15:53:28: UTC offset: 1
15:53:28: PID: 4112
15:53:28: CWD: C://AppData/Roaming/FAHClient
15:53:28: OS: Windows 7 Professional
15:53:28: OS Arch: AMD64
15:53:28: GPUs: 1
15:53:28: GPU 0: NVIDIA:1 GT200GL [Quadro FX 3800]
15:53:28: CUDA: 1.3
15:53:28: CUDA Driver: 5050
15:53:28:Win32 Service: false
15:53:28:***********************************************************************
15:53:28:<config>
15:53:28: <!-- Folding Core -->
15:53:28: <checkpoint v='10'/>
15:53:28: <cpu-affinity v='true'/>
15:53:28:
15:53:28: <!-- Folding Slot Configuration -->
15:53:28: <power v='full'/>
15:53:28:
15:53:28: <!-- Network -->
15:53:28: <proxy v=':8080'/>
15:53:28:
15:53:28: <!-- Slot Control -->
15:53:28: <pause-on-battery v='false'/>
15:53:28:
15:53:28: <!-- User Information -->
15:53:28: <passkey v='********************************'/>
15:53:28: <team v='10'/>
15:53:28: <user v='Human-Shield'/>
15:53:28:
15:53:28: <!-- Folding Slots -->
15:53:28: <slot id='1' type='CPU'>
15:53:28: <cpus v='-1'/>
15:53:28: </slot>
15:53:28: <slot id='0' type='GPU'/>
15:53:28:</config>
15:53:28:Connecting to assign-GPU.stanford.edu:80
15:53:29:Connecting to assign-GPU.stanford.edu:8080
15:53:50:WARNING:Attempting to update GPUs.txt: Failed to connect to assign-GPU.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:53:50:Trying to access database...
15:53:50:Successfully acquired database lock
15:53:50:Enabled folding slot
15:53:50:ERROR:Exception: Option 'gpu-index' has no default and is not set.
15:53:50:Enabled folding slot 00: READY gpu:0:GT200GL [Quadro FX 3800]
15:53:50:WARNING:WU00:Slot ID 1 no longer exists and there are no other matching slots, dumping
15:53:50:WARNING:WU02:Slot ID 1 no longer exists and there are no other matching slots, dumping
15:53:50:WU00:FS01:Sending unit results: id:00 state:SEND error
UMPED project:7610 run:403 clone:0 gen:265 core:0xa4 unit:0x00000160664f2dd04de6d420430f72ca
15:53:50:WU00:FS01:Connecting to 171.64.65.104:8080
15:53:50:WU01:FS00:Starting
15:53:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
15:53:50:WU01:FS00:Started FahCore on PID 5060
15:53:50:WU01:FS00:Core PID:5072
15:53:50:WU01:FS00:FahCore 0x11 started
15:53:50:WU02:Sending unit results: id:02 state:SEND error
UMPED project:7809 run:7 clone:205 gen:112 core:0xa4 unit:0x000000a60a3b1e874e31149c093a8b2d
15:53:50:WU02:Connecting to 171.64.65.99:8080
15:53:50:WU01:FS00:0x11:
15:53:50:WU01:FS00:0x11:*------------------------------*
15:53:50:WU01:FS00:0x11:Folding@Home GPU Core
15:53:50:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:53:50:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:53:50:WU01:FS00:0x11:Build host: amoeba
15:53:50:WU01:FS00:0x11:Board Type: Nvidia
15:53:50:WU01:FS00:0x11:Core :
reparing to commence simulation
15:53:50:WU01:FS00:0x11:- Looking at optimizations...
eleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:53:50:WU01:FS00:0x11:- Created dyn
15:53:50:WU01:FS00:0x11:- Files status OK
15:53:50:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
15:53:50:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
15:53:50:WU01:FS00:0x11:- Digital signature verified
roject: 10501 (Run 32, Clone 0, Gen 1333)
15:53:50:WU01:FS00:0x11:Assembly optimizations on if available.
15:53:50:WU01:FS00:0x11:Entering M.D.
15:53:56:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
15:53:56:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
15:53:57:WU01:FS00:0x11:Working on Protein
15:53:58:WU01:FS00:0x11:Client config unavailable.
15:53:58:WU01:FS00:0x11:Starting GUI Server
15:53:58:WU01:FS00:0x11:mdrun_gpu returned
15:53:58:WU01:FS00:0x11:NANs detected on GPU
15:53:58:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
15:54:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:54:11:WU00:FS01:Connecting to 171.64.65.104:80
15:54:11:WARNING:WU02:WorkServer connection failed on port 8080 trying 80
15:54:11:WU02:Connecting to 171.64.65.99:80
15:54:11:WU00:FS01:Server responded WORK_ACK (400)
15:54:11:WU00:FS01:Cleaning up
15:54:12:WU02:Server responded WORK_ACK (400)
15:54:12:WU02:Cleaning up
15:54:44:Adding folding slot 01: READY cpu:12
15:54:44:WU00:FS01:Connecting to assign3.stanford.edu:8080
15:54:45:Removing old file 'configs/config-20130718-095141.xml'
15:54:45:Saving configuration to config.xml
15:54:45:<config>
15:54:45: <!-- Folding Core -->
15:54:45: <checkpoint v='10'/>
15:54:45: <cpu-affinity v='true'/>
15:54:45:
15:54:45: <!-- Folding Slot Configuration -->
15:54:45: <power v='full'/>
15:54:45:
15:54:45: <!-- Network -->
15:54:45: <proxy v=':8080'/>
15:54:45:
15:54:45: <!-- Slot Control -->
15:54:45: <pause-on-battery v='false'/>
15:54:45:
15:54:45: <!-- User Information -->
15:54:45: <passkey v='********************************'/>
15:54:45: <team v='10'/>
15:54:45: <user v='Human-Shield'/>
15:54:45:
15:54:45: <!-- Folding Slots -->
15:54:45: <slot id='0' type='GPU'/>
15:54:45: <slot id='1' type='CPU'>
15:54:45: <cpus v='-1'/>
15:54:45: </slot>
15:54:45:</config>
15:55:06:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:55:06:WU00:FS01:Connecting to assign4.stanford.edu:80
15:55:06:WU00:FS01:News: Welcome to Folding@Home
15:55:06:WU00:FS01:Assigned to work server 171.64.65.101
15:55:06:WU00:FS01:Requesting new work unit for slot 01: READY cpu:12 from 171.64.65.101
15:55:06:WU00:FS01:Connecting to 171.64.65.101:8080
15:55:27:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:55:27:WU00:FS01:Connecting to 171.64.65.101:80
15:55:29:WU00:FS01
ownloading 536.84KiB
15:55:29:WU00:FS01
ownload complete
15:55:30:WU00:FS01:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:7647 run:178 clone:0 gen:140 core:0xa4 unit:0x000000b7664f2dcd4fa7fe957e673231
15:55:30:WU00:FS01:Starting
15:55:30:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -np 12
15:55:30:WU00:FS01:Started FahCore on PID 4832
15:55:30:WU00:FS01:Core PID:4864
15:55:30:WU00:FS01:FahCore 0xa4 started
15:55:30:WU00:FS01:0xa4:
15:55:30:WU00:FS01:0xa4:*------------------------------*
15:55:30:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
15:55:30:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
15:55:30:WU00:FS01:0xa4:- Looking at optimizations...
15:55:30:WU00:FS01:0xa4:- Created dyn
15:55:30:WU00:FS01:0xa4:- Files status OK
15:55:30:WU00:FS01:0xa4:- Expanded 549214 -> 848748 (decompressed 154.5 percent)
15:55:30:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=549214 data_size=848748, decompressed_data_size=848748 diff=0
15:55:30:WU00:FS01:0xa4:- Digital signature verified
roject: 7647 (Run 178, Clone 0, Gen 140)
15:55:30:WU00:FS01:0xa4:Assembly optimizations on if available.
15:55:30:WU00:FS01:0xa4:Entering M.D.
15:55:36:WU00:FS01:0xa4:Mapping NT from 12 to 12
15:55:36:WU00:FS01:0xa4:Completed 0 out of 2500000 steps (0%)
16:17:04:WU00:FS01:0xa4:Completed 25000 out of 2500000 steps (1%)
16:37:37:WU00:FS01:0xa4:Completed 50000 out of 2500000 steps (2%)
16:58:14:WU00:FS01:0xa4:Completed 75000 out of 2500000 steps (3%)
17:18:47:WU00:FS01:0xa4:Completed 100000 out of 2500000 steps (4%)
17:39:24:WU00:FS01:0xa4:Completed 125000 out of 2500000 steps (5%)
18:00:06:WU00:FS01:0xa4:Completed 150000 out of 2500000 steps (6%)
18:20:43:WU00:FS01:0xa4:Completed 175000 out of 2500000 steps (7%)
18:41:21:WU00:FS01:0xa4:Completed 200000 out of 2500000 steps (8%)
19:01:56:WU00:FS01:0xa4:Completed 225000 out of 2500000 steps (9%)
19:22:32:WU00:FS01:0xa4:Completed 250000 out of 2500000 steps (10%)
19:43:06:WU00:FS01:0xa4:Completed 275000 out of 2500000 steps (11%)
20:04:02:WU00:FS01:0xa4:Completed 300000 out of 2500000 steps (12%)
20:24:39:WU00:FS01:0xa4:Completed 325000 out of 2500000 steps (13%)
20:45:17:WU00:FS01:0xa4:Completed 350000 out of 2500000 steps (14%)
21:06:04:WU00:FS01:0xa4:Completed 375000 out of 2500000 steps (15%)
21:26:38:WU00:FS01:0xa4:Completed 400000 out of 2500000 steps (16%)
21:47:15:WU00:FS01:0xa4:Completed 425000 out of 2500000 steps (17%)
******************************* Date: 2013-07-18 *******************************
22:07:52:WU00:FS01:0xa4:Completed 450000 out of 2500000 steps (18%)
22:28:29:WU00:FS01:0xa4:Completed 475000 out of 2500000 steps (19%)
22:49:06:WU00:FS01:0xa4:Completed 500000 out of 2500000 steps (20%)
23:09:35:WU00:FS01:0xa4:Completed 525000 out of 2500000 steps (21%)
23:30:41:WU00:FS01:0xa4:Completed 550000 out of 2500000 steps (22%)
23:55:20:WU00:FS01:0xa4:Completed 575000 out of 2500000 steps (23%)
00:16:28:WU00:FS01:0xa4:Completed 600000 out of 2500000 steps (24%)
00:37:01:WU00:FS01:0xa4:Completed 625000 out of 2500000 steps (25%)
01:01:54:WU00:FS01:0xa4:Completed 650000 out of 2500000 steps (26%)
01:22:08:WU00:FS01:0xa4:Completed 675000 out of 2500000 steps (27%)
01:43:24:WU00:FS01:0xa4:Completed 700000 out of 2500000 steps (28%)
02:04:05:WU00:FS01:0xa4:Completed 725000 out of 2500000 steps (29%)
02:24:40:WU00:FS01:0xa4:Completed 750000 out of 2500000 steps (30%)
02:45:13:WU00:FS01:0xa4:Completed 775000 out of 2500000 steps (31%)
03:05:52:WU00:FS01:0xa4:Completed 800000 out of 2500000 steps (32%)
03:26:29:WU00:FS01:0xa4:Completed 825000 out of 2500000 steps (33%)
03:47:09:WU00:FS01:0xa4:Completed 850000 out of 2500000 steps (34%)
04:07:46:WU00:FS01:0xa4:Completed 875000 out of 2500000 steps (35%)
******************************* Date: 2013-07-19 *******************************
04:28:18:WU00:FS01:0xa4:Completed 900000 out of 2500000 steps (36%)
04:48:48:WU00:FS01:0xa4:Completed 925000 out of 2500000 steps (37%)
05:09:23:WU00:FS01:0xa4:Completed 950000 out of 2500000 steps (38%)
05:30:03:WU00:FS01:0xa4:Completed 975000 out of 2500000 steps (39%)
05:50:45:WU00:FS01:0xa4:Completed 1000000 out of 2500000 steps (40%)
06:11:26:WU00:FS01:0xa4:Completed 1025000 out of 2500000 steps (41%)
06:32:02:WU00:FS01:0xa4:Completed 1050000 out of 2500000 steps (42%)
06:52:44:WU00:FS01:0xa4:Completed 1075000 out of 2500000 steps (43%)
07:13:31:WU00:FS01:0xa4:Completed 1100000 out of 2500000 steps (44%)
07:34:15:WU00:FS01:0xa4:Completed 1125000 out of 2500000 steps (45%)
07:55:02:WU00:FS01:0xa4:Completed 1150000 out of 2500000 steps (46%)
08:02:31:FS00:Shutting core down
08:02:31:FS01:Shutting core down
08:02:39:WU00:FS01:0xa4:Client no longer detected. Shutting down core
08:02:40:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
08:02:40:WU00:FS01:Starting
08:02:40:WARNING:WU00:FS01:Changed SMP threads from 12 to 11 this can cause some work units to fail
08:02:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -np 11
08:02:40:WU00:FS01:Started FahCore on PID 1520
08:02:40:WU00:FS01:Core PID:5352
08:02:40:WU00:FS01:FahCore 0xa4 started
08:02:40:WU00:FS01:0xa4:
08:02:40:WU00:FS01:0xa4:*------------------------------*
08:02:40:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
08:02:40:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
08:02:40:WU00:FS01:0xa4:- Looking at optimizations...
08:02:40:WU00:FS01:0xa4:- Files status OK
08:02:40:WU00:FS01:0xa4:- Expanded 549214 -> 848748 (decompressed 154.5 percent)
08:02:40:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=549214 data_size=848748, decompressed_data_size=848748 diff=0
08:02:40:WU00:FS01:0xa4:- Digital signature verified
08:02:40:WU00:FS01:0xa4:Assembly optimizations on if available.
08:02:40:WU00:FS01:0xa4:Entering M.D.
08:02:46:WU00:FS01:0xa4:Using Gromacs checkpoints
08:02:46:WU00:FS01:0xa4:Mapping NT from 11 to 10
08:02:46:WU00:FS01:0xa4:Resuming from checkpoint
08:02:46:WU00:FS01:0xa4:Verified 00/wudata_01.log
08:02:47:WU00:FS01:0xa4:Verified 00/wudata_01.trr
08:02:47:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
08:02:47:WU00:FS01:0xa4:Verified 00/wudata_01.edr
08:02:47:WU00:FS01:0xa4:Completed 1150690 out of 2500000 steps (46%)
08:03:32:WARNING:FS00:Killing WU01
08:03:32:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:03:33:Removing old file 'configs/config-20130718-130705.xml'
08:03:33:Saving configuration to config.xml
08:03:33:<config>
08:03:33: <!-- Folding Core -->
08:03:33: <checkpoint v='10'/>
08:03:33: <cpu-affinity v='true'/>
08:03:33:
08:03:33: <!-- Network -->
08:03:33: <proxy v=':8080'/>
08:03:33:
08:03:33: <!-- Slot Control -->
08:03:33: <pause-on-battery v='false'/>
08:03:33:
08:03:33: <!-- User Information -->
08:03:33: <passkey v='********************************'/>
08:03:33: <team v='10'/>
08:03:33: <user v='Human-Shield'/>
08:03:33:
08:03:33: <!-- Folding Slots -->
08:03:33: <slot id='0' type='GPU'/>
08:03:33: <slot id='1' type='CPU'>
08:03:33: <cpus v='-1'/>
08:03:33: </slot>
08:03:33:</config>
08:22:56:WU00:FS01:0xa4:Completed 1175000 out of 2500000 steps (47%)
08:31:02:WU01:FS00:Starting
08:31:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
08:31:02:WU01:FS00:Started FahCore on PID 5432
08:31:02:WU01:FS00:Core PID:1552
08:31:02:WU01:FS00:FahCore 0x11 started
08:31:03:WU01:FS00:0x11:
08:31:03:WU01:FS00:0x11:*------------------------------*
08:31:03:WU01:FS00:0x11:Folding@Home GPU Core
08:31:03:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:31:03:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:31:03:WU01:FS00:0x11:Build host: amoeba
08:31:03:WU01:FS00:0x11:Board Type: Nvidia
08:31:03:WU01:FS00:0x11:Core :
08:31:03:WU01:FS00:0x11:- Looking at optimizations...
08:31:03:WU01:FS00:0x11:- Created dyn
08:31:03:WU01:FS00:0x11:- Files status OK
08:31:03:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
08:31:03:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
08:31:03:WU01:FS00:0x11:- Digital signature verified
08:31:03:WU01:FS00:0x11:Assembly optimizations on if available.
08:31:03:WU01:FS00:0x11:Entering M.D.
08:31:09:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
08:31:09:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
08:31:09:WU01:FS00:0x11:Working on Protein
08:31:12:WU01:FS00:0x11:Client config unavailable.
08:31:12:WU01:FS00:0x11:Starting GUI Server
08:31:12:WU01:FS00:0x11:mdrun_gpu returned
08:31:12:WU01:FS00:0x11:NANs detected on GPU
08:31:12:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:32:40:FS00:Shutting core down
08:33:41:WARNING:FS00:Killing WU01
08:33:41:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:43:47:WU00:FS01:0xa4:Completed 1200000 out of 2500000 steps (48%)
08:52:36:WU01:FS00:Starting
08:52:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
08:52:36:WU01:FS00:Started FahCore on PID 1892
08:52:36:WU01:FS00:Core PID:6048
08:52:36:WU01:FS00:FahCore 0x11 started
08:52:36:WU01:FS00:0x11:
08:52:36:WU01:FS00:0x11:*------------------------------*
08:52:36:WU01:FS00:0x11:Folding@Home GPU Core
08:52:36:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:52:36:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:52:36:WU01:FS00:0x11:Build host: amoeba
08:52:36:WU01:FS00:0x11:Board Type: Nvidia
08:52:36:WU01:FS00:0x11:Core :
08:52:36:WU01:FS00:0x11:- Looking at optimizations...
08:52:36:WU01:FS00:0x11:- Created dyn
08:52:36:WU01:FS00:0x11:- Files status OK
08:52:36:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
08:52:36:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
08:52:36:WU01:FS00:0x11:- Digital signature verified
08:52:36:WU01:FS00:0x11:Assembly optimizations on if available.
08:52:36:WU01:FS00:0x11:Entering M.D.
08:52:39:FS00:Shutting core down
08:52:42:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
08:52:42:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
08:52:42:WU01:FS00:0x11:Working on Protein
08:52:44:WU01:FS00:0x11:Client config unavailable.
08:52:44:WU01:FS00:0x11:Starting GUI Server
08:52:44:WU01:FS00:0x11:mdrun_gpu returned
08:52:44:WU01:FS00:0x11:NANs detected on GPU
08:52:44:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:53:40:WARNING:FS00:Killing WU01
08:53:40:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:04:46:WU00:FS01:0xa4:Completed 1225000 out of 2500000 steps (49%)
09:25:01:WU00:FS01:0xa4:Completed 1250000 out of 2500000 steps (50%)
09:45:24:WU00:FS01:0xa4:Completed 1275000 out of 2500000 steps (51%)
10:05:49:WU00:FS01:0xa4:Completed 1300000 out of 2500000 steps (52%)
10:11:07:WU01:FS00:Starting
10:11:07:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
10:11:07:WU01:FS00:Started FahCore on PID 5544
10:11:07:WU01:FS00:Core PID:3932
10:11:07:WU01:FS00:FahCore 0x11 started
10:11:08:WU01:FS00:0x11:
10:11:08:WU01:FS00:0x11:*------------------------------*
10:11:08:WU01:FS00:0x11:Folding@Home GPU Core
10:11:08:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
10:11:08:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
10:11:08:WU01:FS00:0x11:Build host: amoeba
10:11:08:WU01:FS00:0x11:Board Type: Nvidia
10:11:08:WU01:FS00:0x11:Core :
10:11:08:WU01:FS00:0x11:- Looking at optimizations...
10:11:08:WU01:FS00:0x11:- Created dyn
10:11:08:WU01:FS00:0x11:- Files status OK
10:11:08:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
10:11:08:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
10:11:08:WU01:FS00:0x11:- Digital signature verified
10:11:08:WU01:FS00:0x11:Assembly optimizations on if available.
10:11:08:WU01:FS00:0x11:Entering M.D.
10:11:14:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
10:11:14:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
10:11:15:WU01:FS00:0x11:Working on Protein
10:11:17:WU01:FS00:0x11:Client config unavailable.
10:11:17:WU01:FS00:0x11:Starting GUI Server
10:11:17:WU01:FS00:0x11:mdrun_gpu returned
10:11:17:WU01:FS00:0x11:NANs detected on GPU
10:11:17:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
10:18:08:FS00:Shutting core down
10:19:09:WARNING:FS00:Killing WU01
10:19:09:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:26:05:WU00:FS01:0xa4:Completed 1325000 out of 2500000 steps (53%)
10:46:24:WU00:FS01:0xa4:Completed 1350000 out of 2500000 steps (54%)
10:46:43:WU01:FS00:Starting
10:46:43:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
10:46:43:WU01:FS00:Started FahCore on PID 5364
10:46:43:WU01:FS00:Core PID:2044
10:46:43:WU01:FS00:FahCore 0x11 started
10:46:43:WU01:FS00:0x11:
10:46:43:WU01:FS00:0x11:*------------------------------*
10:46:43:WU01:FS00:0x11:Folding@Home GPU Core
10:46:43:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
10:46:43:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
10:46:43:WU01:FS00:0x11:Build host: amoeba
10:46:43:WU01:FS00:0x11:Board Type: Nvidia
10:46:43:WU01:FS00:0x11:Core :
10:46:43:WU01:FS00:0x11:- Looking at optimizations...
10:46:43:WU01:FS00:0x11:- Created dyn
10:46:43:WU01:FS00:0x11:- Files status OK
10:46:43:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
10:46:43:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
10:46:43:WU01:FS00:0x11:- Digital signature verified
10:46:43:WU01:FS00:0x11:Assembly optimizations on if available.
10:46:43:WU01:FS00:0x11:Entering M.D.
10:46:49:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
10:46:49:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
10:46:50:WU01:FS00:0x11:Working on Protein
10:46:52:WU01:FS00:0x11:Client config unavailable.
10:46:52:WU01:FS00:0x11:Starting GUI Server
10:46:52:WU01:FS00:0x11:mdrun_gpu returned
10:46:52:WU01:FS00:0x11:NANs detected on GPU
10:46:52:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
10:47:32:FS00:Shutting core down
10:48:33:WARNING:FS00:Killing WU01
10:48:33:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:06:42:WU00:FS01:0xa4:Completed 1375000 out of 2500000 steps (55%)
11:27:06:WU00:FS01:0xa4:Completed 1400000 out of 2500000 steps (56%)
11:38:39:WU01:FS00:Starting
11:38:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
11:38:39:WU01:FS00:Started FahCore on PID 3044
11:38:39:WU01:FS00:Core PID:416
11:38:39:WU01:FS00:FahCore 0x11 started
11:38:40:WU01:FS00:0x11:
11:38:40:WU01:FS00:0x11:*------------------------------*
11:38:40:WU01:FS00:0x11:Folding@Home GPU Core
11:38:40:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
11:38:40:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
11:38:40:WU01:FS00:0x11:Build host: amoeba
11:38:40:WU01:FS00:0x11:Board Type: Nvidia
11:38:40:WU01:FS00:0x11:Core :
11:38:40:WU01:FS00:0x11:- Looking at optimizations...
11:38:40:WU01:FS00:0x11:- Created dyn
11:38:40:WU01:FS00:0x11:- Files status OK
11:38:40:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
11:38:40:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
11:38:40:WU01:FS00:0x11:- Digital signature verified
11:38:40:WU01:FS00:0x11:Assembly optimizations on if available.
11:38:40:WU01:FS00:0x11:Entering M.D.
11:38:46:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
11:38:46:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
11:38:47:WU01:FS00:0x11:Working on Protein
11:38:49:WU01:FS00:0x11:Client config unavailable.
11:38:49:WU01:FS00:0x11:Starting GUI Server
11:38:49:WU01:FS00:0x11:mdrun_gpu returned
11:38:49:WU01:FS00:0x11:NANs detected on GPU
11:38:49:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
11:42:26:FS00:Shutting core down
11:43:27:WARNING:FS00:Killing WU01
11:43:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:47:25:WU00:FS01:0xa4:Completed 1425000 out of 2500000 steps (57%)
11:52:12:WU01:FS00:Starting
11:52:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
11:52:12:WU01:FS00:Started FahCore on PID 1052
11:52:12:WU01:FS00:Core PID:2612
11:52:12:WU01:FS00:FahCore 0x11 started
11:52:12:WU01:FS00:0x11:
11:52:12:WU01:FS00:0x11:*------------------------------*
11:52:12:WU01:FS00:0x11:Folding@Home GPU Core
11:52:12:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
11:52:12:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
11:52:12:WU01:FS00:0x11:Build host: amoeba
11:52:12:WU01:FS00:0x11:Board Type: Nvidia
11:52:12:WU01:FS00:0x11:Core :
11:52:12:WU01:FS00:0x11:- Looking at optimizations...
11:52:12:WU01:FS00:0x11:- Created dyn
11:52:12:WU01:FS00:0x11:- Files status OK
11:52:12:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
11:52:12:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
11:52:12:WU01:FS00:0x11:- Digital signature verified
11:52:12:WU01:FS00:0x11:Assembly optimizations on if available.
11:52:12:WU01:FS00:0x11:Entering M.D.
11:52:18:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
11:52:18:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
11:52:19:WU01:FS00:0x11:Working on Protein
11:52:21:WU01:FS00:0x11:Client config unavailable.
11:52:21:WU01:FS00:0x11:mdrun_gpu returned
11:52:21:WU01:FS00:0x11:NANs detected on GPU
11:52:21:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
12:07:12:FS00:Shutting core down
12:07:43:WU00:FS01:0xa4:Completed 1450000 out of 2500000 steps (58%)
12:08:13:WARNING:FS00:Killing WU01
12:08:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:14:22:WU01:FS00:Starting
12:14:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users//AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
12:14:22:WU01:FS00:Started FahCore on PID 5424
12:14:22:WU01:FS00:Core PID:6516
12:14:22:WU01:FS00:FahCore 0x11 started
12:14:22:WU01:FS00:0x11:
12:14:22:WU01:FS00:0x11:*------------------------------*
12:14:22:WU01:FS00:0x11:Folding@Home GPU Core
12:14:22:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
12:14:22:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
12:14:22:WU01:FS00:0x11:Build host: amoeba
12:14:22:WU01:FS00:0x11:Board Type: Nvidia
12:14:22:WU01:FS00:0x11:Core :
12:14:22:WU01:FS00:0x11:- Looking at optimizations...
12:14:22:WU01:FS00:0x11:- Created dyn
12:14:22:WU01:FS00:0x11:- Files status OK
12:14:22:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
12:14:22:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
12:14:22:WU01:FS00:0x11:- Digital signature verified
12:14:22:WU01:FS00:0x11:Assembly optimizations on if available.
12:14:22:WU01:FS00:0x11:Entering M.D.
12:14:28:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
12:14:28:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
12:14:29:WU01:FS00:0x11:Working on Protein
12:14:31:WU01:FS00:0x11:Client config unavailable.
12:14:31:WU01:FS00:0x11:Starting GUI Server
12:14:31:WU01:FS00:0x11:mdrun_gpu returned
12:14:31:WU01:FS00:0x11:NANs detected on GPU
12:14:31:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
12:24:22:FS00:Shutting core down
12:28:00:WU00:FS01:0xa4:Completed 1475000 out of 2500000 steps (59%)
12:31:02:WARNING:FS00:Killing WU01
12:31:02:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:31:41:13:127.0.0.1:New Web connection
12:31:52:WARNING:Exception: 18:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
12:31:56:FS01:Shutting core down
12:31:56:WU01:FS00:Starting
12:31:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/L/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
12:31:56:WU01:FS00:Started FahCore on PID 964
12:31:56:WU01:FS00:Core PID:5824
12:31:56:WU01:FS00:FahCore 0x11 started
12:31:57:WU01:FS00:0x11:
12:31:57:WU01:FS00:0x11:*------------------------------*
12:31:57:WU01:FS00:0x11:Folding@Home GPU Core
12:31:57:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
12:31:57:WU01:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
12:31:57:WU01:FS00:0x11:Build host: amoeba
12:31:57:WU01:FS00:0x11:Board Type: Nvidia
12:31:57:WU01:FS00:0x11:Core :
12:31:57:WU01:FS00:0x11:- Looking at optimizations...
12:31:57:WU01:FS00:0x11:- Created dyn
12:31:57:WU01:FS00:0x11:- Files status OK
12:31:57:WU01:FS00:0x11:- Expanded 62894 -> 336763 (decompressed 535.4 percent)
12:31:57:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62894 data_size=336763, decompressed_data_size=336763 diff=0
12:31:57:WU01:FS00:0x11:- Digital signature verified
12:31:57:WU01:FS00:0x11:Assembly optimizations on if available.
12:31:57:WU01:FS00:0x11:Entering M.D.
12:32:02:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr: 1629719815 3940959380 699480707 98139461 3779876519
12:32:02:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
12:32:03:WU01:FS00:0x11:Working on Protein
12:32:03:WU00:FS01:0xa4:Client no longer detected. Shutting down core
12:32:03:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
12:32:03:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
12:32:04:WU00:FS01:Starting
12:32:04:WARNING:WU00:FS01:Changed SMP threads from 11 to 12 this can cause some work units to fail
12:32:04:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 4112 -checkpoint 10 -np 12
12:32:04:WU00:FS01:Started FahCore on PID 5752
12:32:04:WU00:FS01:Core PID:6708
12:32:04:WU00:FS01:FahCore 0xa4 started
12:32:04:WU01:FS00:0x11:Client config unavailable.
12:32:04:WU00:FS01:0xa4:
12:32:04:WU00:FS01:0xa4:*------------------------------*
12:32:04:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
12:32:04:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:32:04:WU00:FS01:0xa4:- Looking at optimizations...
12:32:04:WU00:FS01:0xa4:- Files status OK
12:32:04:WU00:FS01:0xa4:- Expanded 549214 -> 848748 (decompressed 154.5 percent)
12:32:04:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=549214 data_size=848748, decompressed_data_size=848748 diff=0
12:32:04:WU00:FS01:0xa4:- Digital signature verified
12:32:04:WU00:FS01:0xa4:Assembly optimizations on if available.
12:32:04:WU00:FS01:0xa4:Entering M.D.
12:32:04:WU01:FS00:0x11:Starting GUI Server
12:32:04:WU01:FS00:0x11:mdrun_gpu returned
12:32:04:WU01:FS00:0x11:NANs detected on GPU
12:32:04:WU01:FS00:0x11:Folding@home Core Shutdown: UNSTABLE_MACHINE
12:32:10:WU00:FS01:0xa4:Using Gromacs checkpoints
12:32:10:WU00:FS01:0xa4:Mapping NT from 12 to 12
12:32:10:WU00:FS01:0xa4:Resuming from checkpoint
12:32:10:WU00:FS01:0xa4:Verified 00/wudata_01.log
12:32:10:WU00:FS01:0xa4:Verified 00/wudata_01.trr
12:32:10:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
12:32:10:WU00:FS01:0xa4:Verified 00/wudata_01.edr
12:32:10:WU00:FS01:0xa4:Completed 1468570 out of 2500000 steps (58%)
Hope that helps
Latest drivers as of yesterday.
