IM having a major problem with my PC lately...
Im getting som CRC errors when I try to uncompress a .rar files larger than 300mb, also this problem afect the .cab files So I cant install almost all my favorite games...
I dont think is a software problem because I just format my PC and try: Vista x64 (my default), vista x32, XP SP2 and the same problem apear...
I have read in other forums that this problem is related with some bad memory issue, so I try 1 by 1 all my stick of ram and the problem persist.. either with 1gb,2gb or 4gb. I also try a friend's ram and the problem persist....
this is frustrating, I have a $4,000 PC for just word processing
I just bought this motherboard and I hope is not the MB because is almost imposible to RMA to tigerdirect because I live in other country.. I was hoping it was the ram because they are cheap....
anybody with a solution or the same problem???
I will try to update the bios later, Also try to change the SATA cables... another idea or posible solution?
Spec:
Q6600 (I tried OC and stock)
Maximus formula SE
8800 ultra
4gb OCZ reapers
TT toughpower 750w
Spec:
Maximus formula SE
8800 ultra
4gb OCZ reapers
TT toughpower 750w
