Hi there,
this morning i got my T240HD delivered from overclockers. I set it up so that my laptop screen is turned off and only the T240HD displays stuff. However after i restart the computer it is fine up til the moment that i have enterd my vista password. It then reverses to normal display settings ie both displays nect to eahc other. And then even though everything is displayed on the T240HD screen i have an overlay that says "Check signal cable." If i then change the settings back to just the samsung screen, the overlay check signal cable thing wont dissappear.
I dont know where to go from here while this is just about ok to write for support it is obviously not a solution for anything else.
Thanks Jerome
Thanks Jerome
