Hi,
Ive just got 2 2503 routers, and I'm just trying to get them to ping each other, problem is is that I cant even get the status on either router to go into the up position for any length of time let along the protocol status.
Im going into the interface, setting an ip address and subnet mask, setting the clockrate on the DCE end, and giving the no sutdown command, but this is still not allowing the status to go into the up position.
I know that the protocol status is down as i havent configured a route or given a routing protocol, but surly the status should be up? Im used to 2601's which we use at uni and they're a little different.
What do you recon is the problem? Im begining to think its a possible cable problem?
