Problem with server
23 Jun 2005
York
Hey all,
I've just got my CS:S server up and running.
After configuring Mani Admin plugin I set an admin bind key to "a". Not realising that once the window is open I can't move left (as it is also the walk left key!) I changed it.
I have unbinded "a" yet when I press "a" I can't move left, the admin box doesn't come up, I just can't move left.
Please help me ASAP.
lucasade1 said:
Hey all,
rebind your a key in the options.
I take it you have re-set a in your controls in options havn't you?
Check your config.cfg file, delete any reference to binding 'a', then try loading the game again.
What options? I did it via the console.
Is this the mani_server.cfg? or one outside of mani?
The options in counter-strike. Press escape > Options > Keyboard etc.
If that fails, the config.cfg in your counter-strike\cfg folder.
