hey there,
after 2 days of battling with them i run out of options. Are there any known issues with z87 chipset and multiple gpu's?
problem is following: i have 2 motherboards 1) asus z87a 2) asus sabertooth z87 and 3x r9 280x. When 3 of them are plugged in, on powering system on, everything will power up, all the fans will start spinning, even ethernet port will start blinking green/yellow as if it is working, but nothing is being fed to the screen, even bios does not load, just a black screen. each card works fine separately, 2 card work together, 3 - do not. Both motherboards have 3x pcie 16x, both boards support quad gpu's.
most interesting part is in both cases with both boards, CPU error led indicator is lit up red on the board when i try to start with 3 cards in.
rest of the system:
cpu: pentium g3220
ram: 1x4gb ddr3 1333
ssd: samsung 840 128gb
psu: modular 1050w
cards: 2x sapphire dual-x r9 280x + 1x msi gaming oc r9 280x
please advice if any ideas, thank you guys!
rest of the system:
cpu: pentium g3220
psu: modular 1050w
