Problem with Steam - Disk write error *Now solved*
17 May 2013
West Sussex, UK
Not sure where to stick this, so here it is.
I'm unable to install new games, or update existing ones. It starts to download, than pops up this error after 10 seconds.
I've had a Google, and it seems a common problem, but all solutions I've read, haven't worked.
This is only when using the Steam folder on my games HDD. I attempted to install to the default library on C: drive and works OK.
I've tried the following;
1. Repair steam library
2. Change download region
3. Cleared download cache
4. Uninstalled & reinstalled Steam
5. Completely deleted Steam folder and started again
6. Ran check disc - no errors
7. Checked SMART data for disc - 100% health
I've had my Steam library on this HDD for a good 6 months without issue.
It's just dawned on me while typing this, I think this might be the first time I've used Steam since doing a windows reinstall.
Any ideas before I contact Steam for help?
Daft one.. Its not read only? Also, try ticking to box to inherit your new settings. As the write is being done in common I think. Not at my pc (camping atm) so hard to remember what I had to do myself
Silly question - is the drive formatted as FAT32? I've read about similar problems when downloading games with file sizes too big for FAT32.
My steam has started doing similar this week.
Games struggle to install. Take longer to load. Take multiple restarts.. Steam link lags like hell..
Gonna try and reinstall my steam folder on another drive I think.
Have a feeling my hard drive is buggered.
I have checked for 0kb files, non found.
What software is recommended to check the drive. Everything looks fine with the drive.
I still think it's some sort of protection/security on the drive, but not sure
It's definitely not the drive. But something windows 10 related. I had this a few months back but am struggling to remember.
Is there anything in \downloading?
If so, close steam via task manager and delete everything.
