4 Apr 2008 at 23:53 #1 sanofi sanofi Associate Joined 9 Jul 2006 Posts 1,848 Location Vienna Has anyone else had this version of Super Pi begin a test and get stuck after the first iteration?
5 Apr 2008 at 11:38 #2 MikeTimbers MikeTimbers Soldato Joined 18 Oct 2002 Posts 8,307 Location Aranyaprathet, Thailand Link to download?
5 Apr 2008 at 13:24 #3 SinaiSound SinaiSound Soldato Joined 18 Oct 2002 Posts 3,303 Location Sheffield What O/S you using?
5 Apr 2008 at 14:12 #4 Da[]San Da[]San Associate Joined 20 Oct 2002 Posts 1,616 Location North West If your using Vista then there is a known problem
5 Apr 2008 at 17:05 #5 sanofi sanofi Associate OP Joined 9 Jul 2006 Posts 1,848 Location Vienna Yes I am using Vista. Ok, guess I'll stick to the regular version for now.
5 Apr 2008 at 18:38 #6 Da[]San Da[]San Associate Joined 20 Oct 2002 Posts 1,616 Location North West Hi try this.. Turn off Audio services in Vista ( start> run> services.msc, find Windows Audio on the list , double click and stop it ).
5 Apr 2008 at 20:21 #7 jbloggs jbloggs Soldato Joined 4 Sep 2005 Posts 6,803 Location UK Or try running it in XP SP2 Compatability Mode....
5 Apr 2008 at 20:27 #8 sanofi sanofi Associate OP Joined 9 Jul 2006 Posts 1,848 Location Vienna jbloggs said: Or try running it in XP SP2 Compatability Mode.... Click to expand... Thanks, works a charm
