- 29 Jun 2005
- London
I'm reading 54C idle and about 69C on TAT on my E6300 @ 2.3GHz, which I know is high, but I just don't believe the reading. When I boot up from cold (my room is pretty nippy atm too) I go straight into TAT once windows has loaded and the temps are already 45C!?
I do the same with the BIOS and the temps in there read about 12C from cold, I've also tried setting the CPU to stock and the temps are only a couple of degrees cooler.
I know they read from different sensors, but surely the TAT readings are wrong?
Could I have a dodgy sensor?
If so, would it be on the mobo or the CPU?
