Problem with Transmission (Bittorrent)
Caporegime
28 Jun 2005
On the hoods
Transmission decided to update itself the other day. Since then, it appears to be utterly swamping the network connection. If it's downloading, I can't get anything else network-y to work e.g. mail, web.
Any ideas, or is this more likely some bug in the new release?
I can live with downloading when I'm away from the computer for now, but if it's going to be an ongoing thing I'd rather fix it or downgrade to the old version.
Hmm ... maybe the number of simultaneous connections has been changed, making it cripple the router/connection?
Check the number of global connections and/or the maximum connections per new transfer isn't set higher.
Well, I reverted to 1.50 and it works now... Weird. It must be something in my setup that causes the problem, as I'm sure a bug like that would have been caught in testing!
The latest versions of Transmission seem a bit flaky. I find anything past v1.34 doesn't seem to upload as well.
