- 3 Jan 2023
- Hampshire UK
I am a non-IT home network user for my non-IT related home usage. I have TalkTalk FTTC with a TT Router Huawei DG8041W-2.T5. I bought 5 Ubiquiti UAP-AC-LR UniFi AC1300 LR Cloud Managed Access Points w/ 3-Year Hosted Cloud Controller Service from Broadbandbuyer. They set up the cloud controller for me and all seemed fine. I used to get messages whenever an AP went down (for example if I turned off the power to one of them), but those stopped coming a while back - not sure why. The rest of my network is a single LAN cable from the router to an HP unmanaged switch and a combination of hardwired connected things and those that are wirelessly connected to the Ubiquiti APs. All works fine except that every couple of weeks or so, the network seems to drop and I start having connectivity issues with equipment. That gets worse until I do a whole house reboot, then everything is fine for a couple of weeks. I have tried just rebooting the router, just rebooting the APs and just rebooting the network switch, but basically I have to turn everything off and restart. I was using DHCP for everything to assign IP addresses, but have since tried by fixing the IP address of the APs and reserving those in the router.
The problem really goes beyond the little that I know so if there are any good suggestions what this might be, I would be grateful to hear them. Also I have the 3 year cloud hosted controller, but do I actually need that. Another non-IT friend set his Ubiquity Unifi APs up and said he didn't bother with a cloud controller. Just wondering if there is something with the cloud controller that causes issues with the combination with the TT router or router firewall.
Thanks
Thanks
