Problem with USB Card Reader after upgrade to 4400 X2
30 Jul 2005
Hi,
I have just upgraded my ASUS AN8-Sli Premium to a 4400 X2 and fitted a new raptor with fresh install of XP at the same time.
The problem I have is with the USB Card reader. Both a built in Mitsumi 7 in 1 and a separate USB reader plugged in to a USB port.
When I insert a compact flash card or SD card the computer seems to freeze for nearly 10 minutes before the card opens and then the computer returns to normal.
I have upgraded the BIOS and Nvidia chipsets to the latest and all other USB things seem to be working fine.
Does anyone have any experience of similar problems or can offer any tips to try as it is a right pain every time I try and open a few photos on the card.
Thanks
Have you installed all XP updates and the AMD dual core driver/optimiser? Does it freeze the computer if you turn the auto run off?
