- 22 Feb 2014
Bought a used car from a local forecourt back in july/August.
VW Tiguan 2010, 2.0 TDI 140bhp 2WD
On viewing the car had a bit of a rattle which went away with the clutch fully down.
Dealer agreed to replace clutch/flywheel.
Was still a bit of noise when we came to pick it up but dealer said the clutch had been replaced we either accept a refund of deposit or take the car as is and if it gets worse he will help out with repair etc.
Note dealer has his own garage/mechanics.
2nd note, this is not my car it is my partners and I rarely drive it.
fast forward to December I take the car to a local remapper and have it remapped which I think took it up to 180/190bhp, and around 45ft/lb extra torque.
When i collect the car the remapper says there was a rattle before we mapped it which is now worse, we think it is the clutch or flywheel.
Driving home it is pretty bad, flooring it at around 1800 - 2500 rpm results in quite bad juddering/noise from the gearbox side of engine bay. But the engine is fine the dyno printout shows a nice smooth curve and the remapper is happy there are no engine problems.
I spoke to my partner about it when I got home and she says "yeh its always done that but its my first diesel so I didn't know if it was normal or not" *facepalm*
Before I go any further with the story (there is quite a bit more to it) I assume at this point any warranty or consumer rights are out of the window at this point ?
also worth mentioning that the original map has been put back on and it still has the problem just not as bad.
i do also need to mention the clutch and flywheel kit fitted to the car came from these guys
https://uk.trustpilot.com/review/www.ncduk.com
which I believe is causing the problem.
