Yes I know it's a very old B&W printer. I obtained it about 20 years ago for the price of a new HP toner cartridge (about £70).
It has operated very well and has only had one hardware fault previously - the fuser heater failed several years ago. I bought a unit from "the bay" and swapped it and everything was hunkydory again. The toner seemed to be running out recently and the print became faint. So I bought a cheap clone toner cartridge but this didn't improve things. Exactly the some faint print
I have had a play with it and it does seem to be a hardware fault.
From reading up on how a laser printer works is it possible there is something wrong with the corona charging wires / system? Can these be cleaned? Can't actually see them?
Any early HP laser printer experts out there please? Otherwise it's for the "Printerland in the sky".
"Corona wires - There is a primary corona wire and a secondary wire or transfer wire. The primary corona wire is important for charging the drum positively, which is necessary for attracting the toner particles to the surface."
