I recently bought an Asus RT-AC88U WiFi Router for my new apartment. The specs are brilliant:
It quotes "Coverage - Very Large Homes". My new apartment is small, 138 sq.metres, and I have installed the router in the corner of my office, which is exactly at the centre of the apartment, every corner of the apartment is within 10 metres of the router.
The problem is, as soon as I move to the next room, I lose signal. Even in the same room, in the opposite corner I drop a bar on both 2.4Ghz and 5Ghz. I've tried every position of the aerials, put the router vertical and flat, and the same problem occurs.
Yesterday I took two of my old routers to the apartment to test those. Asus RT-AC51U and a TP-Link TD-W8960N. Both of these perform excellently in the apartment, and I get a good signal from every corner of the apartment. So I don't know what the problem is with this new router. Any suggestions?
- Dual-Band Wireless-AC3100 Gigabit Router
- 4x4 antenna design with AiRadar universal beamforming for unbeatable wireless signal coverage
- 8 Gigabit LAN ports for 2x the number of wired ports typically provided
- Unbeatable Wi-Fi Coverage - With a four-transmit, four-receive (4T4R) antenna design, both Wi-Fi range and signal stability improve dramatically. AiRadar beamforming further focuses Wi-Fi signal on your devices, making your Wi-Fi faster, clearer and stronger.
