Problem with Windows 7 Enterprise
7 Jun 2003
Gloucestershire
I decided to create an enterprise image last week as i wanted it's features but this has thrown up a problem...
I have some PCs with this spec:
Asus P8H61-I
Pentium G620T
4GB RAM
OCZ Vertex 2 40GB SSDs
When i image these machines on first boot the PCs go straight to a "System mismanaging PTEs" BSOD with the code 0x000000DA (i think that's right anyway) yet i've imaged lots of other PCs with this same image and not had that problem.
Just to make it even more confusing, i have two images of enterprise, one that contains visual studio 2010 and one that doesn't, the one that doesn't works fine, the one that does is the one that throws up this problem (again, only on these boards) yet the previous image i have of windows 7 professional contains visual studio 2010 and that works fine. :confused:
VS2010 is literally the only change i made between the two images as well. Final thing to note is that these were imaged from a VM in vmware workstation, and i did make sure to remove vmware tools prior to capturing the image.
Reason i'm putting this in here is mainly due to enterprise only being available to SA customers, so i doubt many outside of here have used it.
