Problem with WPN824v2
1 Aug 2006
Cardiff
Titles meant to read WPN824v2 :/
No matter what I cant login to the router, through either using routerlogin.net/com to using 192.168.1.1. I haven't got any passwords set or usernames so I'm only trying to login with the default information, I've tried using both IE and FF both with same result, can anyone tell me what I'm doing wrong? Thanks.
Same router here and both 192.168.1.1 and www.routerlogin.net work for me, how about using the cd to set it up or doing a hard reset?
If not what lights are on on the router?
Wireless light is on since I have a laptop using it, node 4 light since thats my PC, power and the LAN light.
I have installed it all through the install wizard also :/
Do I have to do anything to press the factory reset button, as in should I turn anything off or whatever?
Also thanks for the title change Mr passing Don.
