- 5 Nov 2009
- North-West England
I've experianced a small problem when trying to connect to Xbox live for multiplayer wondering if any of you guys had experianced a similar problem or knew a work-around.
So it starts when i pop the disk into the 360 - I was prompted to download a system update required to play the game, however this goes fine and the xbox restarts as normal.
Second time around i click to select to play the game from the dashboard and select my live account to sign onto and im prompted to download an Xbox live update in order to be able to use live - i choose the "Yes , Update now" option and it takes me to the usual window. After about 3 - 5 minuites of looking at said window ( without the progress tracker/bar actually moving anywhere ) the window closes and another opens telling me the update has failed and there may be a problem with my connection.
After running a the Xbox live connections test from system settings dashboard bit it all appears fine with my connection apart from that it needs the update.
Any help would me greatly appreciated guys
