problem with XP
18 Jan 2005
liverpool
Hi there,
I'm having a problem with my PC, whereby periodically keystrokes no longer result in the appropriate response. most letters fail to type, but some activate dropdown menus, and shortcuts. Also, when this wierd mode activates, clicking on links downloads the webpage and saves it to my desktop instead of activating the link. when i press "Alt-A", everything returns to normal for a random period of time. i've tried running "malwarebytes", but nothing is detected.
any suggestions? this is doing my head in.:mad:
i don't think it's the ctrl key, as the same problem occurrs with different keyboards, and it's not a wireless keyboard. i'll check the startup menu next.
thanks for all the suggestions- i'll keep you posted :)
