Problem witx rtx 3060
15 Aug 2024
Gloucester
Hi! I have problem with rtx3060, hope someone will know answer, whole pc works fine just when lighter shade shows it's doesn't turn darker smoothly - it's like rainbow effect
This is not display problem as I check couple lcd, oled monitors still same
What I can do with this?
Id say thats more an issue with the picture used than the GFX card.
Do you get the same on the default windows desktop pics?
I have this problem also on others pictures and video too, it's like rainbow shows when high white lights should smoothly go down to darker colours
Did anyone have this problem ?
New drivers, uninstall experience etc nothing change
I buy this pc used, from beginning it was like this, all of those I try already including different cable dp/ hdmi still same, it's possible than rtx is broken?
