problem
31 Jan 2009
London
i downloaded a trail for Adobe Premiere CS3, when i try to install it, it loads up the installation then suddenly quits, any takes on this?
im using windows 7 atm
Assuming you downloaded it from the official site, make sure your system meets the minimum requirements, be sure you have permissions on your PC to install programs, close all open applications (reboot!) and try again. If it still doesn't work, the DL may have corrupted. Get it again. If all fails, your PC is b0rked.
pc definatly min spec, downloaded it twice same thing hppend, official site and softpedia..
guess im stuck with movie maker :(
