problems after updating Adobe flash
18 Aug 2010
Scotland
I find that I am able watch some clips, but only after having switched to a different quality setting as with this clip: http://www.break.com/index/worlds-fastest-roller-coaster-1955594
which will fail to run at 360p, but will run at 480p. Same problem with other clips, but if there is no option to change the setting, I am unable to play any clips.
I have uninstalled the flash update and reinstalled, then updated my graphic card driver, cleaned hd.
My connection is 7mbit.
Ideas?
TY in advance
