Hi all,
I recently bought a new GFX card from Overclockers a Zotac GeForce RTX 4090 Trinity and then I got a 1000 PSU to run the card, but since I installed the card I have been having a few start-up problems, first off The computer refused to start properly, it was starting then stopping and then restarting, when it finally restarted it wouldn't allow me into the BIOS screen to reset my memory which had went back to 2100 instead of 3600 it was at, then I noticed that the CMOS battery had died so I replaced the battery, but now it starts on the second attempt but still refuses to let me into the BIOS also My lights on the case and the ram and GFX card don't shut down when I turn off the computer I have to hold the on/off button to get the computer to shut down, as you can probably tell from this post I'm not an expert on computers lol
I should add that the computer came pre-built by PC specialist a couple of years ago and had an overclock preset in the BIOS which seems to have disappeared as well.
and yeah the card is plugged directly into the motherboard, Once the PC boots everything runs properly, all games run well. I had an RTX 2080 before this new card.
