problems booting into windows 10. pls help
14 Aug 2003
cyberspace
Hi,
when trying to boot into windows 10. The boot screen says acer expore beyond limits
"preparing automatic repair" it wont go any further than that. it wont boot into windows 10.
using alt 10 at start up bring up choose an option. when i choose troubleshoot reset this pc remove everything it says reset this pc there was a problem while resetting this pc
also tried advanaced options system restore it says you have to log in as adminsistrator to continue.then it says there are no adminstrator accounts on this pc.
tried command prompt it says you have to log in as adminsistrator to continue.then it says there are no adminstrator accounts on this pc.
tried holding down the power buttom for 20 secs and nothing changes.
the laptops is to Aser Aspire E 15
