Hey I'm having a slight issue getting my PC to boot up.
Seems to be pot luck, one day it will work fine the next it decides it's got other, more important, things to do.
I'll try and describe best I can;
POST screen, it can stay here for aaaages, then will commence to boot.
Sometimes I get message BOOTMNGR is missing ctrl + alt + delete to restart.
Other times it hangs on Windows Loading screen and proceeds to BSOD.
I think its either MB or HDD, but I can't be sure.
Whats your opinion gents, anything I can do?
She's due a format soon so hopefully that would rule corrupt windows (which wouldn't affect post but hey ho)
Thanks
Thanks
