- 27 Jul 2005
- The Orion Spur
Do macbooks have issues connecting wirelessly using wep encryption ?, I've got 2 routers now and I still can't connect my macbook to either of them using wep, if I use no encryption at all then my book connects fine, as soon as I enable wep it won't connect, my other pc laptop connects fine via wep, the router I'm curruntly using is this one http://www.overclockers.co.uk/showproduct.php?prodid=NW-017-NG (Netgear DG834G v3).
, connects fine without wep but as soon as it is enabled it does'nt work, as above you say try doing the following,
, it's ok now though, mac are cool
