Problems connecting to mysql database
28 Feb 2011
Hi
I've installed mysql 64 bit version on windows 7. It has installed and configured ok, the port is open on the firewall and the path variable is set ok. But if I try to log in with mysql u-root p-password it is printing out what seems like the contents of the help file before sending me back to the standard windows command prompt. This is the output I'm getting if it helps.
I've installed SQL server this afternoon on a different machine and it's working ok, I can't see where I'm going wrong this time.
Any help would be much appreciated.
Thanks
