Hello everyone,
I am trying to install the noctua nh-l12 low profile double fan unit.
1. Install back plate - check
2. Install spacers
3. Install brackets
4. Place heat-sink
5. Screw down using the two built in screws
I can slightly twist the heat-sink even though everything is tight, the four screws you add to the spacers and the two heat-sink screws.
Any ideas?
2. Install spacers
3. Install brackets
4. Place heat-sink
Any ideas?
