problems fitting PSU in new case
23 Mar 2007
Essex
hi guys i have just bought the antec 300 case but having a few probs fitting the PSU in it goes down the bottom of the case but there is like a little bracket in the bottom corner that is getting in the way from it sitting flush against the case its screwed in with 2 small type screws looks like they have round heads, just have no idea how to take them out? if someone would not mind helping me out id be very greatfull
cheers
encountered the same problem when i built a system for a friend. in the end, I just bent it down, out of the way, and the PSU went in no problem. Not sure why its there.....
yeah, i tried too, the only thing you can do, is bend it out of the way. No idea what Antec were thinking when they put it there....
it does bend, with a bit of force. I managed to do it with my thumb though it did hurt a bit. Just use a bit elbo grease :)
