- 4 Jan 2004
- Finally, Swindon
Deciding I needed to replace my 5yr old hard drive, I bought a nice new one (thank you MM)
Currently XP boots from a 20GB partition (no, I have no idea why I made it this small)
The rest of the drive is used for programs and storage on a single partition
On the new drive, I want to make the c: partition bigger and thought I could partition it, say 50/415 and using Ghost, clone the 20GB partition to the empty 50GB partition on the new disk (and do the same with the other partition)
The problem is I can't seem to boot from the new drive - I thought the big feature of Ghost was that it did an exact copy, so in theory I should just be able to clone, unplug the old drive, and boot from the new one...or is the problem that I have changed the partition size?
Anyone give me any pointers?
I'm using Ghost 2003 and booting from a floppy to run it
Thanks
Thanks
