- 16 Aug 2011
Having some probs instaling an OS with my new systems build...
I've done this in list format rather than endless paragraphs to keep this simple.
1. Using onboard VGA I booted OK and went into the BIOS and selected the DVD as the first boot device; hard drive as second boot device.
2. I then powered-down and installed graphics card.
3. Connected monitor to graphics card VGA port and booted OK, then put brand new Windows-7 DVD into DVD drive.
4. Windows-7 started setup procedure - language; kboard setup, etc - but then minor artifacts showing on the display and the OS then just hangs.
5. Thinking that something in the BIOS was not seeing the gfx-card, I then powered-down and reconnected the display to the onboard VGA port.
6. Powered-up again, but nothing showing on the display at all - just blank.
7. Powered-down again, reconnected monitor to gfx-card and everything was OK with the monitor.
8. Attempted to install Win-7 again, but same result as for '4'.
9. Powred-down, then tried to see if Win-XP would work, and low and behold Win-XP started installing OK. I had got to the drive partitioning stage.
10. However, I had selected the 'long install' and it was taking for ever; I mean really slow, so I quit the instalation so as to use the 'quick install'.
Problem I now have is, that I get this message after bootup - 'Error loading operating system...', and then the system just idles/hangs.
This now happens all the time, i.e, I am no longer getting the prompt asking me to select the boot device/drive.
What do I do here. I'm in a real fix
Obviously something is now preventing me from loading or installing any OS via the DVD drive.
