Problems logging into PSN ?
23 Dec 2002
Shiny Shanghai
Anyone having this ?
I've been unable to log in for a couple of days now.
I did an network settings check and it succeeds at the first 2 tests (IP detection and internet connectivity I think) but then sticks on the third test for a couple of minutes before failing. The third test is PSN connectivity.
Anyone else or just me ?
It did have a wobbly two nights ago - a DNS error - which is nothing unusual for me. But it's been fine since then.
Hmmm..... :(
I'm just worried some settings have gone wrong on my router somewhere since I also started having trouble getting my emails sent to my windows mail at around the same time.
My ISP's POP account works fine, but my PC will not connect to my Googlemail POP account at all.
Suspuciousness all round and I thought it might be connected to my PSN issues too.
other problems at the same time seem to suggest smt somewhere has went **** up.
reset router ? reenter what settings you had. Mention on eclipse forums as well. Could try a different router troubleshooting etc.
Just spent a fortune on the phone to Eclipse tech support and they are ******* retarded.
I tried giving them the analogy that I want to walk down a path and go from A to B, but I'm finding my path to "B" blocked (can't even ping certain sites they they easily can) and they are responsible for the path. But all they could do is repeatedly say they are not responsible for "B".
I ******* KNOW YOU'RE NOT !!!!
But you ARE responsible for making sure I can get there.
Even the fact that all this happened when they are having "planned maintenance" that shouldn't affect me washed off them like water off a duck's back.
The ususal bumf, have you tried resetting your router etc etc... Thank's for that sage advice you bunch of..... well.... you know !!
