I have an Acer Aspire 5732Z laptop and none of the USB ports work on it. It's running Windows 7 64bit and USB still doesn't work even after a clean install.
Anyway, I thought I would see if they work under Windows XP, and could do with making it dual boot anyway! So I portioned off part of the HDD, and installed XP to drive D:, then I reinstalled Win 7 to dive C:
The problem I have now though is that it still only boots to XP - how do I make it come up with the dual boot menu?
I should add that my system now dhows as having 3 partitions on the HDD. System Reserved (C
, WinXP (D
& Win7 (E
, WinXP (D
& Win7 (E
