im useing
pb5 board
geil ram
tt1200 coloer
i just can not get past 2.7 gb its a 2.4 quad any ideas pleae just will not boot if i try to clock any higher must me the setting as this chip will do 3.6bg i just want 3gb to start
yes working it was the ram setting
booted into windows at 3.6 then rebooted
droped it down to 3.2 for the min to check the temps
full load 55c with pc probe 2 this ok?
Get that beastie folding, you should get 700ppd from that.
We were just saying we need someone with a quad core to knock concorde off the top of the single crunchers league. You up for it?
Good luck getting it clocked.
Surprisingly low temps, all the reviewers reckoned that overclocking would be mainly temp limited and it would require water cooling to achieve full potential.
Glad to hear that's not the case.
if it goes pear shaped is there a easy way to reset the bios with this board
i move the jumpers to reset the bios turn power on power off then put the pin back in the right place and i get no screen take like 20 goes before it setup on the screen?
good good, p5b deluxe recovers very easily without a jumper reset, turn the power of for 5 seconds (from the psu) put it back on and it loads up in recovery mode!
