Hmmm k ppls I recently built a new pc (about 3 months ago..) but I cant seem to get rid of a very annoying prob:
My PC whenver it's stressed I.E. During gaming/Stress Test Etc... Regularly just shuts down... :/ I've noted this prob ever since I built it but @ first I thought it was just because my pc was oc'd far beyond it's limits..
But after setting everything back to stock volts/clocks I still keep getting this prob. Btw this happens to me after a few mins to max an hour into stressing my pc and then it just automatically turns off.. (No Shut down or blue screen.. as if u turned it off from the plug)
Sometimes when it turns off and I switch it back on it turns off again even during the POST.. which seems to rule out a prob from the psu since during a post only a minimal ammount of power is used and also If it was capable of running the pc stable Overclocked to 3.8Ghz from 2.6Ghz stock it should at least work properly @ 2.6Ghz since much less power is being used...
PC Specs Are Here:
Mobo: EVGA 680i LT Mobo with latest bios
CPU: E5300 (Was overclocked to 3.8Ghz @ 1.4v is now back at stock 2.6Ghz)
RAM: 8Gb Crucial 800Mhz Ram (4x2Gb Sticks)
VGA:ATI X1600PRO (Bought as a temporary vga till I buy something better)
Cooling: Adequate (CPU @ ~40C Idle 50C Stressed / N.Bridge 45C S.Bridge 50C)
PSU : Logysis 650W Nominal power output 750W Max (22A 12v1 Rail 22A 12v2 Rail)
Do You think this could possibly be a problem with overheating? since the n.bridge and s.bridge are both running @ about 50C idle?? :/
Thx for ur help ppls
PC Specs Are Here:
oh well i guess It's a risk u must take when building ur own pc eh :/
