Problems playing DVD's in WMP or MPC
20 Oct 2002
London
I always thought Media Player Classic plays them :confused:
I've got a region-free DVD drive and run DVD Region Killer, yet when i try to play DVD's in WMP; it tells me to lower my screen resolution, which does nothing. If i follow the help through it says essentially i need a DVD decoder. If i try to play a DVD in MPC it simply hangs?
How can i play DVD's?
Jeff Crawly said:
To decode mpeg2 in WMP you need a third party DVD Program like WinDVD or PowerDVD.
However VLC is FREE and is a fantastic DVD/mpeg4 player :-)
By the sounds of it MPC should be playing my DVD's. It just doesnt though :confused:
Does anyone use MPC and can/cant play DVD's?
Well i've tried VLC and it seems horrendously complicated. I'm thoroughly confused with why DVD's arent working with MPC. I've tried installing/uninstalling/reinstalling K-Lite codec pack, ffdshow, Haali Media Splitter, Matroska Pack, AC3Filter (lol!!) and MPC still crashes when i load up a DVD. All other vids work fine! I tried VLC and it worked straight away - great... but god its ugly, and horribly overly complex!
I want to stick with MPC, as [a] i like the interface and its worked excellently up till now. Assuming i delete all codecs etc... what do i need to install to make DVD's work? IE on a fresh install what would you have? Just MPC and ffdshow? How about the Matroska Pack? :confused:
And what about setting up different filters in MPC?
on my fresh installs, i have just mpc (there's been some new versions recently, so check that!)
and ffdshow
download the both of them from free-codecs.com, might be crap gfx card drivers
bledd, if you go into Filters > Overrides in MPC do you have anything special setup in there? Or do any overrides appear in there?
Also, in the main Filters options window i have a bunch of things listed (AVI, Ogg , Directshow etc..) is this normal? What do you have selected/deselected?
