This isnt my first PC building, but it might be the last.
First problem i am having is installing the offical intel duo cooler. 3 of the pins seem to be fine, but the 4th just wont click. Which way should they be turned- and why do you need to turn them- it isnt mentioned in the cheap instruction page. I know that intel need to make $5b a year, but they could at least provide some detail. Any more pressure on it and the motherboard will probably break....
Second is installing a Tagan easycon into a lian li PC-7 Plus. Been the fool that i am i followed the case instructions so i took off the back panel put it on the PSU and tried to put the it back in the case. Two problems with this- one is that i am unsure which way the PSU should go- fan up or down. Either all the pictures have the PSU upside down or the fan goes on top, which is something i havent encountered before. Instructions again dont help. With the fan up the PSU wont go more than a few CM as it has been badly manufactured, and with fan down it stops 1/2 way as the fan grill has a huge TAGAN logo stopping it going any further. As i have the Mobo already installed it is nearly impossible to put it in from the inside, and my only attempt at doing so has left a large chuck of paint missing from the PSU.
Any advice would be welcome.
