Just tapping up the helpful folks here for some advice / suggestions for a problem we have. I run a network as a part-time extra string to my bow in work. Our network has a head office with lots of machines, then 1-3 PC's in each of 5 remote locations. Each of these remote locations are connected via an ADSL site to site VPN that is fine for the occasional file transfers that are usually required.
Unfortunately this is all being scuppered by the requirements of a new database reliant HR application. The application is currently installed locally on a management machine at each branch, but it accesses a database at the head office to do anything. The application is windows only, but will run on any version. The network storage is provided by an old Windows 2000 SBS Server that is a little long in the tooth, but does all we need up till this.
Solutions wise I have a couple of options I have looked at:
1. Remote Desktop / Terminal Server: I can run a couple of XP machines left on in the head office. Using these like terminal servers will allow people to log on, but is fairly high bandwidth and not a very clean solution. I could also build a Terminal Server but Windows TS licensing is pricey and Linux + Wine is probably a little beyond my Linux ability (especially as I have never used Wine and the application is not officially supported)
2. Application Streaming (I think): Basically I have seen this app and the functionality sounds ideal: http://www.graphon.com/content/view/9/9/ it allows me to run multiple instances of a single application over the network and will work from a single XP machine. At each remote location they load the application through a kind of mini remote desktop. Again the problem with this is the cost at £169/user/year.
The second option sounds better, but I need to find a cheaper way of doing it. I need it to run at 5-6 machines, but I could probably get away with 3 concurrent users provided it notifies rather than automatically kicking users out.
Any suggestions of solutions used by others, etc are appreciated
