Problems sending texts after jailbreak
5 Oct 2004
Notts
Everything works fine except texts. The progress bar moves as if sending then slows about 4/5th along then says error sending.
Is this more likely to be O2 or a result of the jailbreak?
The same thing happened to me strangely on the day that Yellowsn0w was released. If you have any 3G or issues related to connectivity that you can't sort out with the Airplane mode toggle then head to Settings/General/Reset -> Reset Network Settings and reboot. That should solve most of the issues
