problems setting resolution on titanfall 2...HELP!
17 Jan 2016
isle of wight
I have just got a 40" 4k tv (mostly for films and ps4) but thought I would try a few pc games,most have worked fine but in titanfall 2 it wont even let me choose as high as 1080p?? wtf?
the highest ithe resolution slider will go is 1600x900? anyone know why its doing this?
Thanks
Titanfall 2 runs on source so go into the documents folder for respawn/local/videoconfig and maually edit where it says "setting.defaultres" to "1920" "setting.defaultresheight" to "1080" and it will work this also works for Nvidia DSR. There are a few other tweaks too if you check the thread you can see my link where Nvidia give you tweaks to further boost the graphics through the same config.
