Problems setting up dual boot 11.10/Win7 (64bit) with UEFI bios
Hi
I have just installed the beta version of Ubuntu 11.10 on a new build (with UEFI bios).
With the install done GParted shows the following:
sda1 (unknown filesystem) size 977KiB with a flag bios_grub
sda2 ext4
unallocated (1.4TB)
sda3 swap
However when i try and install Win7 on the unallocated space it won't let me because the Partition Table is GPT (as it is also for sad1/2/3). I gather it needs to be MBR or something.
However i can't see any option in GParted to chage the unallocated space to MBR. Is there anyway to do this?
Or maybe i need to do a compete reinstall and set everything to MBR - i'm assuming here that GParted will give me this option if i start from scratch??
Thanks
diss
Hi
sda2 ext4
unallocated (1.4TB)
sda3 swap
Thanks
diss
